ECM Recall
<div class="FTQUOTE"><begin quote>Originally posted by: brutus450
https://www.polarisdealers.com/servwarr/SrvBulletins/ATV-05-01T%20-%206-27-2005%20Revised%20Safety%20Bulletin%20-%20ECM%20Screening%20Kit.pdf</end quote></div>
I JUST CHECKED MY ECM.......MINE HAS THE GREEN DOT !!! yeeee hah
I have the 4011110 ecm and received a letter BUT according to the Polaris to dealer service bulletin any affected 4011110 ecm that HAS this green dot DOES NOT need to be checked and DOES NOT need to be replaced ! Caper and all you other guys ....check for your GREEN DOT. It is on the top of the ecm on the left side (drivers side if you will) of the unit in the corner. Its real easy to find without removing anything.
Im going to call the dealer and discuss it anyway but it looks like I'm OK
if you go to any dealer and give them the vin number they should be able to look it up and tell you if the recall has been done becasue they record all of the repairs of any bike doen by a dealer.
#16
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
if you go to any dealer and give them the vin number they should be able to look it up and tell you if the recall has been done becasue they record all of the repairs of any bike doen by a dealer.</end quote></div>
When I went back to get my second ECM on my Blue 2006 Sp 450..........They had the first ECM installed under MY WIFE"S YELLOW one...LOL....LOL......So then can get mixed up ....But with me I had two vin numbers for them to Scr&w up!!!........It don't take much to get some Dealers mixed up!!!!.....Caper...........
#17
<div class="FTQUOTE"><begin quote>Originally posted by: JT600
How can you tell if your recall work is done I just received new recall notice and my numbers were in the first one. I have a 600 twin 2005. I was told the work was done when I bought it but I don't know.</end quote></div>
They are supposed to put 2 green paint dots on your ecm if it passed.
#20
I got the letter and now the wife can't find it! Good to know though that
my dealer can look it up. Okay you all, did you replace it yourselfs or
can the dealer send you the part? My dealer is 2 and 1/2 hours away.
Please advise, and thanks!
R'
R'
