Can someone check for me
Old Mar 1, 2008 | 09:56 PM
SCRAMMYTODD's Avatar
Default Can someone check for me
I was plowing a few weeks ago and my check engine light came on for about half an hour and then went out. I don't have my owners manual handy I and wouldn't mind checking the code, but I can't remember the sequence to pull codes agian LOL Lil' help guys and gals [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 1, 2008 | 10:08 PM
JCDEYO25's Avatar
Scrammy...
Not sure if it's the same as my 05 700 but in my manual it says to turn the key on and off 3 times in 5 seconds then leave it on......First it will say wait then the code will appear..Then it will say END..
John
Old Mar 1, 2008 | 10:21 PM
Well it looks like I have a code 41. Anyone wanna check to see what that is?? Thanks JCDEY!!
Old Mar 1, 2008 | 10:33 PM
Rowe's Avatar
Air Temp Sensor Low Voltage
Air Temp Sensor High Voltage
Both came up for a code 41
Old Mar 1, 2008 | 10:36 PM
Well I guess I'll start by checking for snow in the airbox, and then look at the connector. Thanks for the help guys!!
Old Mar 2, 2008 | 12:26 AM
JCDEYO25's Avatar
My machine is throwing that same code.....TBAP sensor...The sensor is right on the rubber boot between the airbox and the throttle body...I'm sure you knew that.....I know on the 05's like mine they ran the harness under the breather hose that goes to the valve cover to the airbox and it rubs on top of the throttle body and wears through the wires in the harness....Gotta pull the harness and flip it over and see if the wires are rubbed thru.....Polaris makes a kit to fix the harness where you cut the old one off and put the new one on.....
John
Old Mar 2, 2008 | 09:08 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would think that code would make the bike run very rich,or maybe even lean? does it have much effect on the 700's guys.
Old Mar 2, 2008 | 12:17 PM
JCDEYO25's Avatar
Sten......
To be honest with you I really can't tell any difference....It runs fine I just checked the codes for the heck of it......Possible one of the wires getting worn or something.....I gotta check it out and will get back to you on the results.......
John
Old Mar 2, 2008 | 11:44 PM
Well I would THINK that the Barometric senser and the Air intake temp senser would throw differant codes. I had a look at mine today and the vent for the trans was resting on the wires at the connector for the air intake temp senser. If I wiggled the wires for the temp senser I could get the check engine light to come on and off. I pulled the pins out of the connector and pried VERY carefully and got the pins to fit better. Now when I give it the "wiggle" test the checkengine light stays off. I rerouted the vent hose out of the way and I'll give it another try next snow fall (hopefully there isn't any more [img]i/expressions/face-icon-small-smile.gif[/img] )
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
