Hawkeye Nighmare
Old Mar 16, 2008 | 09:40 PM
  #21
kowallarry's Avatar
Default Hawkeye Nighmare
Filter was placed on correctly!
Old Mar 16, 2008 | 09:43 PM
  #22
Mongrol's Avatar
"Official Site Skeptic"
I guess the next thing to check for sure is the spark. You said you did that. Did you see a spark or hear it?
Old Mar 16, 2008 | 09:45 PM
  #23
jokout's Avatar
this may sound stupid, but did the fuel shutoff get turned off some how?
Old Mar 16, 2008 | 09:49 PM
  #24
jokout's Avatar
also, did the kill switch on the handle bars get switched off? If this is the case you shouldn't have spark, but I'd check everything at this point!
Old Mar 16, 2008 | 09:51 PM
  #25
miniexcavator's Avatar
how about draining the carb in case theres water in it .its simple to do there is a screw near the bottom of the carb.
Old Mar 16, 2008 | 10:00 PM
  #26
Hawkman300's Avatar
i have the 06 hawkeye. what is the airbox mod and the jetting mod? if it WASNT jetted correctly, what should it act like? im at 0 elevation in FL and it tops out at 50mph.
Old Mar 16, 2008 | 10:04 PM
  #27
Mongrol's Avatar
Your'e ok 300, if you can do 50 thats about tops.
Old Mar 16, 2008 | 10:07 PM
  #28
your fine, the airbox mod was a different way to adjust the carb by drlling holes in the air box and plugging them with rubber plugs, then removing them one at a time to adjust air flow. the dealers were supposed to have this choice or rejetting the carb which is more involved
  #29
Hawkman300's Avatar
what about the airbox mod? was that another factory defect?
Old Mar 16, 2008 | 10:22 PM
  #30
jokout's Avatar
Actually, no. As mini noted this was an easy way for the dealer or you the customer to dial in a slightly misjetted carb...it also works well for owners that ride in varying elevations...many owners do take exception to drilling 6- 3/4" holes in the top of their air box though, especially if you tend to take your Hawkeye swimming in the deeps!
