Hawkeye Nighmare
Old Apr 12, 2008 | 12:40 PM
  #41
snake50's Avatar
Default Hawkeye Nighmare
just wonderin if you fixed the no start problem. I have a 98 300 explorer 2 cycle with no spark. Am in need of help. Have replaced the cdi unit and the rectifier. Am now lost without a wiring diagram to know what wires to test. Please help.
Old Apr 12, 2008 | 01:36 PM
  #42
MECHANIKE's Avatar
take air filter off +get some carb cleaner+see if it will run on carb cleaner,than you'll know it should be carb related....
Old Apr 13, 2008 | 08:00 PM
  #43
Djk's Avatar
Djk
if all the carb and air filter is fine, then its gotta be the boot for your spark plug. it happened to me once too, but i have a 90cc, i was riding along at 30 and then it just shut off, when i turned it back on, it went five, i looked in the boot and on the inside, the metal thing that grabs it was partialy broken, so i just got a new boot and was fine after that.
Old Apr 13, 2008 | 10:33 PM
  #44
jokout's Avatar
If your sure that it has no spark, I would work my way backwards from the spark plug, try a new plug first then check the plug wire and so on...this is the least expensive way to go about it...the process of elimination...eliminating the cheapest/obvious parts first
snowolson
Aug 31, 2015 03:51 PM
Sportsman850
Jul 31, 2015 04:25 PM
GreenHawkeye
Jan 1, 2006 07:16 PM
DAHUI
Dec 17, 2005 06:49 PM
