need info also on oem parts asap
If I have for instance a Sportsman 500 with model #A06MH50AF, and I see a part that says its for #A06MH50AA/AD/AF/FB, that means the part will fit those four different models. Since mine in this example is the AF model, the part number having "AF" in it will fit my model.
Hope this helps.
Hope this helps.
I believe the last two letters just indicate the color (red, blue, camo....). So if you are buying a part independent of color, such as the rear rack, it doesn't matter. For those type parts, it is usually listed like Sheep shows, with all 4 suffixes. Now, if you are buying replacement plastic body pieces, the suffix matters.
bafisher1986
15
07-24-2015 10:18 PM
