3 light mod?
Old Mar 24, 2008 | 04:48 PM
badazzpred's Avatar
Default 3 light mod?
Has anyone done the mod themselves? If so whats the procedure>>>....
thanks
Old Mar 24, 2008 | 05:03 PM
OIown12's Avatar
I did mine. I ordered this. It only took about 10 minutes. Very easy mod!
Old Mar 24, 2008 | 05:43 PM
bbsq00's Avatar
Do a search here you will find many ideas....I am going to do a 1-2-3 light mod with a relay and switch
Old Mar 24, 2008 | 06:10 PM
hobbles's Avatar
Here's another place,, http://www.kfiproducts.com/ind...=viewProd&productId=84
Old Mar 24, 2008 | 11:21 PM
badazzpred's Avatar
Do you think It would be better to wire it with a diode or a relay set-up?
Old Mar 24, 2008 | 11:35 PM
reno82's Avatar
I would think a relay would last longer, but then i got the diode one so who am I to suggest [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 25, 2008 | 11:52 AM
badazzpred's Avatar
I am just wondering if anyone has done the mod themselves? it seems easy enough to do, I would like to know how they did it? is one way better than another? what and where do I get the parts?
Old Mar 25, 2008 | 12:34 PM
quad 4's Avatar
Ok...
Let's start it....
I do it by myself after ALOT of research.....DIODE MOD
You have to buy a heavy duty DIODE...radio shack part *276-1661, they come pack of four...around 2,66$.
Preparation...
You just weld 1 wire's on the ends of each side of the diode and seal with heat shrink. ( I weld a YELLOW and GREEN wire....for later easy connection )
Your looking for the yellow and green wire's coming from the headlight swich. Look at the switch ( there two main loom out of the switch with many wire in ) and follow.......UNDER the top of the headlight pod.
You have to splice in to the wire loom to find the GREEN and YELLOW wires to make some connection.
The rectifier DIODE will ONLY work one way, on mine the GREEN wire goes to the end with the gray stripe, and the black end goes to the yellow wire.
There is a possability of wiring it backwards !!!!!
Try it ....if it dont work just reverse it.
Just get some electric connecter to tap in to the wires under the light pod
YOU DO NOT HAVE TO CUT ANYTHING !
work great since I bought my X2....endjoy
Old Mar 25, 2008 | 02:10 PM
moerules's Avatar
Quad 4 you say to weld or soldier 2 wires to each end? You mean i have a total of 4 wires? to splice in? Sorry just a little more confused know.
Old Mar 25, 2008 | 02:25 PM
quad 4's Avatar
Sorry I did a type error...
you have to weld 1 wire on each side of the DIODE. I weld a yellow wire on the black side and a green one weld on the gray stripe side of the DIODE.
Sorry I'm not perfectly billingual...
