2008 Sportsman 500
2008 Sportsman 500
When I look at my quad from the back end the it is leaning somewhat to the right. I have the machine on a level concrete floor and you can definitely see the lean. Does anybody else have this or is this normal? My co-worker owns a 2007 Sportsman 600 and he says his does the same thing.
2008 Sportsman 500
My truck leans <u>to the left</u> but not my quad. You could put your new quad in my old truck and then it would sit level. [img]i/expressions/face-icon-small-smile.gif[/img] Sometimes when I park in my driveway I lift the back end, and when the weight comes off the suspension the tires slide closer together. Try that and see if it sits level afterward.
2008 Sportsman 500
Earlier I looked at that sig. and thought R tickwad and it made me smile. If that was the intent I guess I'm a little slow. If that wasn't supposed to be funny I'm sorry R. I can be a tickwad sometimes.
If anyone thinks that sounds dirty, you should know that pillow ticking was the preffered wad/patch material for muzzleloaders for hundreds of years and still is. http://www.sagebrushproducts.com/images/tickpatch.jpg
2008 Sportsman 500
I assumed it was ArcticQuad but haven't read any bios yet. I don't even know how. I've only been here a few days.
But I'll tell you what, if you spend 25 hours straight in front of the computer it does something to your mind. <u>Not</u> something good either. [img]i/expressions/face-icon-small-shocked.gif[/img] I was all forumed out when the sun came up on the second day.
2008 Sportsman 500
One of the lower A-arm bolts came loose from my old 400. It eventually bent the a-arm enough that the ATV was leaning to one side. That was the only reason I knew something was wrong. It was pretty amazing that only one lower a-arm bolt held the hub and wheel on. I must have rode it for months this way. The a-arm was so twisted that it had to be replaced. Lesson learned - use red loctite when reassembling the rear suspension after a bearing replacement.
bzdok1234
30
02-23-2016 01:55 PM
Donniereble
08-21-2015 10:46 AM
