Can I lower the clutch engagement rpm on an older 500?
Old May 12, 2008 | 02:32 PM
TheWanderer's Avatar
Default Can I lower the clutch engagement rpm on an older 500?
I've got an older Sportsman 500 (1997), nice clean, low mileage unit I picked up dirt cheap.
Anyways, one of the things that bugs me is that in 4HI you have a to rev it a little bit more than I'd like to get going.
In 4LO, it engages & move as soon as you touch the throttle.
I'm wondering if there's a way (kit) to lower the rpm at which the clutch engages by about 200-300.
Old May 12, 2008 | 03:18 PM
MECHANIKE's Avatar
YEAH,CAN CHANGE THE ENGAGEMENT RPM BY A DIFFERENT SPRING.I DID THAT YESTERDAY.
Old May 12, 2008 | 04:34 PM
drlang's Avatar
I would look at the belt, it might be severely worn. Just a thought. Doc
Old May 12, 2008 | 05:00 PM
MECHANIKE's Avatar
YEAH YOUR RIGHT DR IT SOUNDS MORE LIKE A SLIPPING BELT
Old May 13, 2008 | 10:42 AM
Belt is brand new.
It's not that it doesn't have any power or feels like it's slipping at all.
It's more that I tend to drive like an old man & want it to more or less engage as soon as I touch the throttle.
Old May 13, 2008 | 10:58 AM
MECHANIKE's Avatar
you might want to first look+ see what the color of your primary clutch spring is,mine on a stock 01 scram 500 4x4 stock is polaris blue green.
Old May 13, 2008 | 05:23 PM
drlang's Avatar
That is what I kinda meant, the factory stuff engages off idle. I can't think of a spring lighter than the polaris blue/green. Maybe go with a touch heavier weights. Doc
Old May 13, 2008 | 06:29 PM
sprinter10's Avatar
when it starts moving in low is when it starts moving in high when you shift that is after the clutch in the gear case not the clutch you have something like warn buttons in your clutch or something like that and it is slipping and you don't know it but were it engages in low is were it engages in high it doesn't change when you shift from one to the other.
Old May 15, 2008 | 07:52 PM
MECHANIKE's Avatar
yeah dr i changed from a stock-blue green which is right off idle to a epi brite green + its major revs diff,even though the specs are real close.
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
ghost civic
Jul 15, 2015 10:48 PM
