New 96 Sport 400 owner
thanks for the reply
did the plug and it has a K&N filter so I cleaned and re-lubed
on the belt, anything in particular I should look for? probably a good idea to have a spare belt on hand?
lastly, my coolant seems to be a bit under the min line. do I fill at cap or at the red capped opening on the side of the coolant tank? that one's a little hard to get at
thanks
thanks
Here's what I would do. Make sure it's full at the cap with the engine running. That way you know there aren't any air bubbles in it, then fill to the right level on the overflow. If you need a funnel to reach and don't have one, you can make one out of a paper plate. The grease-resistant kind are great. Tear it straight across from the edge to the middle and make a cone. Tear the tip off the cone if the hole is too small.
<div class="FTQUOTE"><begin quote>Originally posted by: heavywear
thanks Jumbo!</end quote></div>
No problem. You can get some help from other threads here too. I saw a thourouh pre-ride checklist someone was going through. Just check the name of the threads for clues. If you run into problems there are guys here that know A LOT more than me.
09-30-2015 01:37 AM
