400cc 2-stroke
Old Jun 8, 2008 | 01:54 PM
  #31
user493's Avatar
Moto Psycho
Default 400cc 2-stroke
Allllrighty then! [img]i/expressions/face-icon-small-smile.gif[/img] I need a quad by the end of the month though.
Old Jun 9, 2008 | 03:14 AM
  #32
duster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: sjbr549
the counterbalance drain is a 10mm bolt next to the starter.you'll have to remove the skid plate to get to it.the plug thats missing i think is to put oil in the counterbalance.</end quote></div>
Thanks for the clarification.
I knew oil was coming out of there, I just needed to be 100% sure I was draining it from the intended spot. 10mm screw/bolt is what it is...
The old man at the polaris shop did say to fill in the big front hole until oil runs out... I guess like you would for a trans or gearcase.
Interesting thing has happened for me though.... Maybe I had the front end more downhill than I thought... but I drained from the bottom 10mm screws... and when I opened the front plug to fill, oil ran out it. I looked over the position of the bike and the location of these openings in relation to each other and it just didn't look right.
I have a pretty good eye for level/pitch... but it was awful hot out at the time...
But still I trusted my eye more, so I lifted the rear to see if any more came out. Then I replaced all the bolts and filled through the dipstick to be sure.
Old Jun 9, 2008 | 03:23 AM
  #33
duster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
I would change that oil frequently a few times after riding instead of just topping it off, just in case the motor flush missed anything.</end quote></div>
I'm going to keep changing it frequently for a while.
Probably before every considerable ride for a while.
The oil that came out today looked real funny. But it was hard to be sure of what I was looking at. Looked like some red clay dust in the oil. But honestly, the 0w30 is a weird greenish tint to start with, and the motor flush I used was red, and the catch pan was black.
I found no gritty feel replacing the plugs except on the front one. I poured flush through it again, and tried to be sure I got it all out.
I think I caught the issue before it did damage, but I'm still going to drain often and inspect the appearance for a while for piece of mind.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
NatePerz
Jul 27, 2015 03:27 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Jul 7, 2015 11:00 PM
