smoke showing
Old Jun 5, 2008 | 01:00 PM
MagnumPO's Avatar
Default smoke showing
I finally got my rig back up and running after replacing the flywheel key. it is running like it has in the past which is bad. It is smokey and keeps fouling the plug. I think it has to do with the choke cable I replaced recently. The book says it may be improperly routed, bent or in need of adjustment. I see how to adjust it with the little wheel in the middle. It is all the way closed now (the little wheel) so it can only go one way and that doesnt seem to help. any idea what it could be? Airfilter is clean, compression is good, ignition system too.
2000 magnum 500
thanks
Old Jun 5, 2008 | 01:03 PM
user493's Avatar
Moto Psycho
Shouldn't the choke be all the way OPEN, not closed? Except when you first start it with a cold engine?
Old Jun 5, 2008 | 06:40 PM
MagnumPO's Avatar
i dont know, its in the same position as the one I replaced and it ran good. i just keep tinkering with it.
Old Jun 5, 2008 | 08:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it a choke or an enricher? most of the time you shouldnt even need the choke to start when its warmer weather.
Old Jun 5, 2008 | 09:01 PM
MagnumPO's Avatar
book uses both terms but no i dont usually use it. i replaced it because i broke the lever while removing the front plastic. anyway i got a new choke cable and replaced it I must have messed something up because something has been a little off since then and it has gotten worse.
Old Jun 6, 2008 | 07:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its an enrichern, most likely you could have it adjusted wrong and its not seating all the way down letting to much gas in. kinda the same way w/ a butterfly style choke. make sure there is a little slack in the lever if its a flip up style.
Old Jun 6, 2008 | 08:34 AM
MagnumPO's Avatar
ok thanks
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Sw00p
Sep 24, 2015 02:50 PM
