Wobbly Front Wheels at High Speed
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
If it had fix-a-flat put in and not driven enough to spread it around it can make a big lump. You have to pull the tires to see if there's a ball of it in there. But, that's my second guess. Toe-out is my first. </end quote></div>
I guess I need to run it some more before I panic. It may work itself out.
The wobble happened on pavement since it was just a quick test drive in front of my house right after buying it. I need to get it to the dirt and see if it still does it.
The toe-out.............. how is that supposed to be set? Toed out? Or toed in? How much? Any tips on how to check it and/or make any necessary ajdustments?
UPLou
06-07-2015 09:42 AM
