96 500 sportsman...how do I flush the radiator?
Old Jul 8, 2008 | 03:44 PM
pwoens's Avatar
Default 96 500 sportsman...how do I flush the radiator?
Everything is running great with the HO head, carb, pipe, etc... but it is running REALLY hot. I had to remove the rad hose to replace the head so im thinking maybe I got soem air in the system. What/how is the best way to flush the system of any air bubbles and to help it run cooler?
thanks
Old Jul 9, 2008 | 12:14 AM
Run with radiator cap open,adding coolant as it goes down. You will see bubbles and if thermostat,water pump ok,will usually see big gulp when fan kicks on,top off coolant,replace cap. Sometimes I have to use a handfull of shop towels to keep from puking out while purging air from system. Just takes a little while. Good luck.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
panicmanic
Sep 28, 2015 12:59 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Logan Collins
Sep 5, 2015 08:03 PM
