how much oil
Old Jul 11, 2008 | 07:28 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default how much oil
"THERE IS NO OIL" in the base of a 2 stroke period! the only oil would be from the injection or the premix. do they use assembly lube to put an engine back together but theres not that much of it. its fine and a good idear to premix 1 tank of gas w/ the injection oil for a new rebuild. the 300's didnt come w/ a counter balancer like the 400's did so no dip stick. imo.
Old Jul 11, 2008 | 09:20 AM
colt2245p's Avatar
yes i know the 400 2 stroke has a dipstick on the case below the carb. it only holds about 4 ounces of oil. i am not sure about the 300. it needs to be check regularly. on the old one we had it have to have oil added regularly. it was overlooked for awhile and the crank bearings let loose one day. this oil is to lube the crank bearings i believe.
Old Jul 11, 2008 | 06:38 PM
crensign's Avatar
so all this said how often if ever should i drain the oil mix out of the crank case..... is this ever done or does it not need anything.....
thank you
Old Jul 16, 2008 | 05:46 PM
blaster24's Avatar
i dont know about the po po but my blaster takes gear oil in the crankcase to lube the crank and bearings and it is a 2-stroke i mix my gas at 32 to 1 i also use klotz 2-stroke oil and have yet to foul a plug!
Old Jul 16, 2008 | 06:17 PM
  #15
sheepdogMSP8117's Avatar
I've never heard of a 2-stroke taking oil in the "crankcase". Gearcase yes, and if there is a separate case for the counterbalancer, then yes, but not the crankcase.
Old Jul 16, 2008 | 06:38 PM
  #16
blaster24's Avatar
sheep not sure if there is a seperate case for the counterbalencer or not on the blaster but the gear oil goes on the clutch side to lube the clutches i also think it lubes the crankshaft and the counterbalencer not sure on the po po though since it is a automatic.please correct me if im wrong! thanks alot.
