polaris mag 325
Old 08-06-2008 | 10:33 PM
toyota_tech's Avatar
Default polaris mag 325
hey im new here but any way my polaris has a rear end issue i think i went to take off and something snaped and now i can see my shaft turning all the way in to the case but no movement of the tires if anyone can help i would greatly appericiate it and if i can help anyone with there cars feel free to ask thank you
Old 08-06-2008 | 11:09 PM
There is a grease fitting in rear frame of magnum on shaft that people over look! Most likely splines on short prop shaft stripped at coupler end. Have replaced several. Easier just to jack up and pull rear end out since you have just a small hole to work with that shaft and coupler are in. Make sure to order o-ring that goes in coupler. Rear end should be ok since harder steel than coupler,just usually coupler and propshaft if splines worn. Good luck
Old 08-07-2008 | 07:18 PM
hey thanks for your help i took the rear axel out and the splins do look worn how do u get the shaft seperated from the rear end and the other end comen from the trans out again thanks
Old 08-07-2008 | 08:49 PM
ESCAVADER's Avatar
The hubs are aluminum,the shaft is steel.All you should have to replace is the hub.Polaris designed it this way.Its a posy rear end ,instead of the rear end giving out the hubs do.Changed my 02s twice and 00s once.Take the tire off ,cotter pin and nut hubs come right off.
Old 08-07-2008 | 09:56 PM
Are you talking about rear drive shaft or shaft from rear end into trans area? As worded in your post sounded like propshaft tuning in TRANS case but not rear driveshaft? Or are you talking about stripped hub on rear driveshaft?Have had hubs strip as posted above by ESCAVADER and propshaft couplers bad to!!
Old 08-08-2008 | 08:25 PM
ESCAVADER's Avatar
MABEY I misunderstood what he was trying to describe.If your asking how to unhook the driveshaft from the rear end ,remove the rearend[you might need a prybar,a couple of tabs on the right side need to be tweeked to pull it out.The driveshaft between the gearcase and rear end have a slip spline in it.Iremoved the 4 bolts on the housing on the end of the driveline to aid in removal.iNEVER HEARD OF SOMEONE wearing out the slip spline never greased it its possible i guess.
ALAN
Old 08-08-2008 | 10:52 PM
Yes this coupler will strip because hard to see grease fitting,can on see it through small hole in swing arm,especially if used in wet conditions.have replace on a couple magnums and a Ranger.
Ramman1
08-11-2022 01:53 PM
Cole Hadden
08-24-2020 11:11 PM
NoJoke
08-09-2015 12:39 PM
Polaris Side by Sides
07-30-2015 12:14 PM
maxjung
07-13-2015 05:11 PM
Quick Reply: polaris mag 325
