battery not staying up
Old Aug 12, 2008 | 01:08 PM
michael l's Avatar
Default battery not staying up
have a 05 sportsman 800 twin. battery low so put new one on and within a couple of hours it was low. charged it up and still low after a couple of hours. can anyone help?
Old Aug 12, 2008 | 01:47 PM
deerwagon's Avatar
Don't know if this helps, but... I replaced my battery on my 05' 700 efi and withing two days it was dead. I brought the battery back to the dealer and they tested it and said it was a bad battery. They replaced it at no charge and I haven't had a problem since (6 mths). I also installed a "battery tender". Awesome product - cost around $30. It has a quick connect to the battery and can be plugged in whenever you like. I only plug mine in if I'm going riding the next day or in the extreme cold of the winter. It's suppose to extend your battery life 2-3 fold. Good Luck, If it's something more serious I'm sure that the pro's will be on shortly to help.
Old Aug 12, 2008 | 02:42 PM
michael l's Avatar
thanks for replying to the message. the only thing is it keep a charge after i charged it up. it didn't run down until i started riding it. i called the dealer here and they said there is a "ECM POWER BOX" below the handle bars that might be going out. has any body had this power box go out or had problems if it?
Old Aug 12, 2008 | 04:45 PM
SCRAMBLER500XXX's Avatar
VOLTAGE REGULATOR POOPED OUT OR STATOR NOT CHARGING
Old Aug 12, 2008 | 11:22 PM
user493's Avatar
Moto Psycho
The 800 was just about the only thing made that year that wasn't recalled for a bad ECM but that still doesn't mean it's not the problem. I just don't know how it could have anything to do with it not charging.
Old Aug 13, 2008 | 08:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i think if you check up under the front grill area you'll see the voltage regulator. make sure it isnt unplugged or isnt all corroded and need to have the connections cleaned. if all is good then i would guess it is bad which controls the amount of voltage. imo.
Hunter100us
Oct 7, 2015 11:46 PM
cody500ho
14
Aug 14, 2015 05:03 PM
ScopeZ_
Jul 28, 2015 01:44 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
