Wire conector Weatherproofing Dielectric compound
Old Aug 30, 2008 | 12:28 PM
ZAKAZIM's Avatar
Default Wire conector Weatherproofing Dielectric compound
Looking to weather proof all the wire connectors on my X2. I live in the area of Florida that Fay dumped 32 1/2 " of rain on our normal riding area. Needles to say it is now very wet. I am looking for some input on the best sealer and corrosion resisting compounds available?
Preventive maintenance is a key .....IT SUCKS TO BE TOWED OUT>
Old Aug 30, 2008 | 12:44 PM
MECHANIKE's Avatar
i used liquid elecrical tape.you can get it at home depot or menards.nothing going to get in there.
Old Aug 30, 2008 | 04:50 PM
user493's Avatar
Moto Psycho
I've only used dielectric grease on connectors but the it doesn't make a seal. MECHANIKE's idea sounds a lot better.
Old Aug 30, 2008 | 09:17 PM
MD80 Driver's Avatar
I have had my 500 X2 in water up to the the top of the air intake numerous times and have had no problems at all. I spend most if my time in mud or water, than an hour cleaning my machine with a pressure washer and it has always started without hesitation! However, I did use dielectrical grease on my sons Polaris 90 to cure a water/electrical problem. If you use enough dielectric grease I think it will seal enough but without creating problems if you have to disconnect the electrical conections. Hope this helps!
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
