CODE 41 & 46
Old Sep 1, 2008 | 10:20 PM
Default CODE 41 & 46
Also just disconnect positive battery lead for about 5 minutes and see if codes still show up! As posted above speedo NOT always accurate on codes! Good luck.
Old Sep 1, 2008 | 10:38 PM
G.A.S.'s Avatar
Will removing the fuses do the same thing as disconnecting the battery??
Old Sep 1, 2008 | 11:02 PM
Not always,because system still has power,better to disconnect and eliminate ALL power,sometimes like rebooting a computer(which is what you are doing). Keep us posted! Good luck.
Old Sep 3, 2008 | 04:06 PM
SCRAMBLER500XXX's Avatar
it will be the t-bap sensor wire harness to blame, I have seen this 25 times this year already, the sensor hardly ever fails usually the wire breaks inside of the wire insulation, so you will not be able to see that it is broken. as far as it works now, probably just making contact inside of insulation, usually you can move wire and it will work again for a short time.
part number is 2875542 t-bap harness, should only take your dealer half an hour to repair this if not they are trying to screw you.
t-bap stands for temperature and barometric pressure sensor
Old Sep 3, 2008 | 04:48 PM
  #15
G.A.S.'s Avatar
Thanks Scrambler. I think i will try and bring it in next week.
Old Sep 3, 2008 | 10:39 PM
  #16
<div class="FTQUOTE"><begin quote>Originally posted by: SCRAMBLER500XXX
t-bap stands for temperature and barometric pressure sensor</end quote></div>
[img]i/expressions/face-icon-small-happy.gif[/img] YEP thats why they are back ordered! Waiting on a couple my self
Old Sep 4, 2008 | 01:09 PM
  #17
polaris was supposed to have them in warehouse by last friday, hopefully get mine today, also waiting for a pair.
Old Sep 4, 2008 | 02:38 PM
  #18
G.A.S.'s Avatar
Spoke to the service manager at my dealer. He said they ordered 5 and they are in tranit. Should arive this week so I will bring it in early next week. I love to ride this machine but I have had it in the shope almost for 1 month of the 5 months I have owned it. Hopefully this is the last time for a long time!!!
Old Sep 12, 2008 | 11:29 AM
  #19
xcrider's Avatar
I just had the same thing happen on my 05 700EFI. Turns out the sensor wire had worn thru the insulation and finally broke the wire. It was wearing on the breather tube going running between the air box and engine. Replaced with the kit tied the new harness up and away from the breather tube and all is well again.
Old Sep 12, 2008 | 05:12 PM
  #20
G.A.S.'s Avatar
Got the call today. Atv is ready to be picked up. You guys were right it was the harness. Replaced under warranty. I am going to drive the **** out of it tommorow to see what I can break next. Thanks again for all your input.
Cheers.
G.A.S.
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
