trailboss 250
Old Sep 9, 2008 | 03:41 AM
wartdog's Avatar
Default trailboss 250
hey all when i get up to higher revs i get a sudden loss of power. the engine is fine but the clutch drive is slipping?? is this maybe a worn belt or something in the gearbox? anyhelp is appreciated
Old Sep 9, 2008 | 04:40 AM
Trailboss725's Avatar
does it fall on its face or does it just bogg down when you start going fast???
Old Sep 9, 2008 | 05:29 AM
wartdog's Avatar
goes fine then sudden loss of power. if you change to lo or reverse it will start working again,the problem happens in high generally.
feels like you get up to a good speed then bam
Old Sep 11, 2008 | 06:18 AM
wartdog's Avatar
if it was the belt slipping then when u pull back the revs wouldn't it catch again?? this does not happen. has anyone had this problem, gearbox maybe??
Old Sep 11, 2008 | 09:47 AM
sassee's Avatar
Sounds like a belt/clutch issue, not gearbox. Take the cover off of it and take a DRY spin to see what's happening. If you have slippage, where is it coming from (drive clutch? driven clutch? both?) Could be a bad belt, could be ramp buttons in secondary. worst case bad springs in primary.
Old Sep 12, 2008 | 03:53 AM
wartdog's Avatar
will do, all i have done so far is have a good clean in there and run the revs up without a belt to see if the clutch in the front is operating properly it looks ok but will try your suggestion soon, thanksfor the reply.
Old Sep 12, 2008 | 09:16 AM
Kerbbirds's Avatar
Sounds like the buttons in the secondary clutch are worn out,
Old Sep 12, 2008 | 03:57 PM
Muddyrunner1's Avatar
Ok from what I know it seems to be the buttons on the secondary clutch are either wore out or broke off...a noise will tell you they are broken.
Old Sep 13, 2008 | 01:32 AM
wartdog's Avatar
thanks guys. now i will find a dealer to get the parts. theres not too many around here
68_327_c20
Nov 25, 2023 12:26 PM
Magistar
Apr 13, 2023 04:39 AM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
2000Polaris
Sep 13, 2000 10:22 PM
