Best choice for replacement axle?
Old Sep 22, 2008 | 08:49 PM
Scramble96's Avatar
Default Best choice for replacement axle?
Does anyone have a recommendation for the best replacement axle for a 05 Sportsman 700EFI? I see some cheap ones on ebay for about $150-$200 and they claim a 1 year warranty, but I can't help being suspicious of them. I can get an OEM Polaris for about $250, and then there are the Gorilla and HighLifter Axles for $350 each. Where is my money best spent? I trail ride, play in the mud a little and plow my driveway in the winter. Is it worth the extra money for the Gorilla or Highlifter? Is there a head to head comparison of them anywhere? I have not been able to find anything.
Old Sep 22, 2008 | 08:58 PM
Have ordered Gorilla for one customer,not that awful familiar with aftermaket drive shafts,but matched up to oem only visible difference to my naked eye was that the gorilla shaft was larger/beefier,dont know about the guts though! Some other members experienced with aftermarket assemblies should give you a better answer. Good luck
Old Sep 22, 2008 | 11:04 PM
Scramble96's Avatar
Thanks for the info. Are axle problems common from your experience? I have has several Polaris ATV's in the past, and this is the first axle problem I have had.
ftwflh's Avatar
THere is a guy on ebay called CVMAN and his axles are great
Old Sep 23, 2008 | 12:02 AM
Scramble96's Avatar
I will take a look. Thanks for the tip!
Does anyone know if I can just replace one at a time? Or if I have to replace both at once to keep things 'even' if I switch to something other than OEM?
Old Sep 23, 2008 | 07:56 AM
ftwflh's Avatar
I replaced one with no problems
Old Sep 23, 2008 | 10:01 AM
Kerbbirds's Avatar
I have also dealt with cv man he has a great reputation and a great product and fast service.
Old Sep 23, 2008 | 06:11 PM
Scramble96's Avatar
I'll give CV Man a try. I hope they hold up!
greg74
Sep 10, 2019 03:03 PM
RickyMac
Mar 5, 2016 07:27 AM
velcro7279
Aug 24, 2015 01:15 PM
toonces
Jul 28, 2015 01:58 PM
Rider252
Jul 6, 2015 03:37 PM
