05 sportsman 400 won't start with key
Old Sep 27, 2008 | 07:47 PM
deputysheriff24's Avatar
Default 05 sportsman 400 won't start with key
does anyone know what to do. my sportsman will not crank with the key. everything turns on and i can pull start it, but when i turn the key it just makes a single clicking sound each time i turn it over. i might could fix it if i knew what it was. the troubleshooting guide said to flip the circuit breaker, but i can't find it or a fuse.
Old Sep 27, 2008 | 08:41 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Check your battery voltage.......May not have enough to turn the engine over.......Caper......
Old Sep 27, 2008 | 08:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
w/ the key turned on try jumping the 2 big cables on the solnoide to see if the engine turns over. if so then the solnoide is bad. first thing to do is check battery voltage to see how many volts the battery puts out and check the connections to make sure thier tight and corrsion free. just a couple of idears.
Old Sep 28, 2008 | 12:38 AM
i switched the battery for the one in my wife's wheeler and the batteries cranked hers just fine. she has an 06 sportsman 450. how do i check the voltage?
Old Sep 28, 2008 | 03:04 AM
user493's Avatar
Moto Psycho
Get a voltage meter. I got a cheap multi-meter from Radio Shack YEARS ago and love it. You should have AT LEAST 12v at the battery when not running and 13.5-14v when the engine is running.
Old Sep 28, 2008 | 10:03 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: deputysheriff24
i switched the battery for the one in my wife's wheeler and the batteries cranked hers just fine. she has an 06 sportsman 450. how do i check the voltage?</end quote></div>
well if the battery will crank hers over rthem heck connections and the solnoide like i said. if it still wont turn it over then maybe the starter is the issue. let us know.
Old Sep 28, 2008 | 07:56 PM
shank0668's Avatar
sure she has a newer and bigger one
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
Raccar1
Jun 18, 2015 02:17 AM
1000gade
May 27, 2015 12:37 PM
