breaking traction...
Old Oct 15, 2008 | 01:14 PM
DeathValleyReaper's Avatar
Default breaking traction...
i took my quad to west virginia to ride a week ago, and every time ide get it over 50mph my back tires would break traction and cause me to slide all over the place. but it only does this when i lay down on the throttle, but it never did this before. any reasons or causes that would result in broken traction? my tires are newish and have been on it for a while so i know its not that...
Old Oct 15, 2008 | 01:25 PM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>every time ide get it over 50mph my back tires would break traction and cause me to slide all over the place. but it only does this when i lay down on the throttle</end quote></div>
Is that not what a 525 Outlaw is supose to do? Be worried the day when you lay on the gas and the rear wheels do not spin.
Old Oct 15, 2008 | 04:42 PM
700 sportsman's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
Is that not what a 525 Outlaw is supose to do? Be worried the day when you lay on the gas and the rear wheels do not spin.</end quote></div>
exactly what outlaws are meant to do
Old Oct 15, 2008 | 07:28 PM
hddoperator's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 700 sportsman
exactly what outlaws are meant to do</end quote></div>
at 50 mph? Sounds pretty mean!
Old Oct 16, 2008 | 08:18 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its called real good power. just let off the throttle. the more aggresive the tires the easier they'll spin as well from less ground being contacted w/ less tread. imo.
Old Oct 16, 2008 | 11:50 AM
it has Maxxis Razr-R tires on it and they have never given me any trouble, but latley it just loses control at around 50 or so. i know it used to stick to the ground like it was on rails but the last few times i rode it and i openedit up, traction would break on one tire and throw me around a bit. all ive done to it latley is take the spark arrestor out, but i doubt that is it...
Old Oct 16, 2008 | 03:21 PM
sjbr549's Avatar
check the tire pressures in the rear
Old Oct 17, 2008 | 12:11 AM
Doctorturbo's Avatar
GOT BOOST!
Sounds like something is broken in the rear end. Jack one side up, leave one tire on the ground and start it up and see if both tires pull.
Something is broken for sure.
Old Oct 17, 2008 | 10:59 AM
It also may be tread wear. A sport tire like that will loose its squared off edges after awhile and will slide much more easily. The squared edges of a new tire give a ton more bite. A worn tire would slide much more easily especially on hard packed surfaces.
nastyblaster100
Sep 13, 2015 01:19 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
black798
Sep 9, 2015 07:42 AM
atvcollector
Sep 8, 2015 05:11 PM
