Polaris Sportsman 90 2001 - Too wet?
Old Oct 23, 2008 | 03:28 PM
bweymouth's Avatar
Default Polaris Sportsman 90 2001 - Too wet?
I just picked up a 2001 Polaris sportsman 90 for my son. It ran fine when I brought it home, but when I washed it completely, it won't start. I assume I got some water in the carb or electronics. Are these quads prone to drown out pretty easily? If so, any way I can seal it off better?
Thanks!
Old Oct 23, 2008 | 06:47 PM
Posssible water in stator area. IF you cant start after sitting a while,remove plastic cover on right side,if have air compressor and blow gun,just blow water out from flywheel/pickup coil area. Also check connections on coil and cdi. Kinda hard to keep water/dust,etc out of the older ones since cover slotted for ventilation! Newer ones have snorkel tubes that do a little better job. Good luck
Old Oct 24, 2008 | 07:13 PM
bweymouth's Avatar
Thanks! I took off the cover and cleaned all the contacts of the stator and there is still no spark. How do you know if the stator is bad? Is this common on these?
Old Oct 24, 2008 | 07:48 PM
bweymouth's Avatar
Actually I just looked at the plug again and noticed that there is a tiny bit of spark. But, it seems very intermittant. Does this mean that the stator is ok. What else could be causing a low intermittant spark? I'm puzzled...
Old Oct 24, 2008 | 11:10 PM
If it ran fine before you washed it,then moisture still probably the problem. Early models did have stator problems partially because of the open area around the stator attracting dirt and mud shorting out stator,but when they are bad NO spark at all! if have compressor,blow out all connections at coil,cdi and try to get behind flywheel area. Good luck
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Coryco
Jul 6, 2015 07:30 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
