OVERRIDE / REV LIMITER QUESTION
ok so i know there are alot of topics on this out there.. but i read alot about d/c the black wire to disable it. well i have to hold my override button in just to get it into rev. by the way its a 94 400L 4x4... anyway i d/c that black wire and WALA.. it works... EXCEPT... when i go to turn the key off... it dont shut off... what the hell.... any help here would be kool
Go here http://parts.polarisind.com/Br...asp?RedirectFromDEX=Y
and put in your model, year etc and go to the "Electrical/taillight assy" page.
Number 41 is the reverse limiter box. Number 40 is the cdi bracket and it shows a picture of the cdi but no part number(on that page anyway)
What is the problem you are javing with the machine? Are you just trying to eliminate the reverse limiter?
its a 94 400L.. i have to hold the override switch in for it to go into rev.. some time its it works without but not really...im tryin to figure out how to fix it so i dont have to hold in the override... only if i need to go into 4x4 in rev.. i understand i need that... but it gets old havin to hold that damn button everytime you go in reverse
<div class="FTQUOTE"><begin quote>Originally posted by: HARLEY_OWNER
so what will happen if i plug that one back in.. and d/c the black one from the rev box.?? will the 4x4 still work in rev?></end quote></div>
4X4 should still work(you will still have to hit the override button though). If you do that the machine will not have the limit capability and it will shut off with the key still.
Steeldon
09-09-2015 09:38 AM
