Sportsman 500 AWD problem
Old Nov 3, 2008 | 05:58 PM
chikester's Avatar
Default Sportsman 500 AWD problem
My speedometer broke and I took it out to try to repair it. Turned out I ruined it beyond putting back together so I no longer have a speedometer. I have read the forums about grounding the white/brown wire for your AWD to work by bypassing the speedometer. I assume this is if you have speedometer correct? I can not expect this procedure to work without a speedomete correct? Thanks in advance.
Old Nov 3, 2008 | 06:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that is a very good question. since you have no speedo to put back in if you can find the right wire it might be worth a quick try. dont know if differnt years had differnt locations of the wire or if they all were the same. just becasreful not to screw up the awd circuit by shorting it out.
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
