Ball joints
Old Nov 10, 2008 | 07:47 PM
Default Ball joints
Puller has a thick plate that mounts to 2 screw slots on strut bottom,a threaded bolt with nut screws through this plate into balljoint.Just hold bolt head and tighten nut which sucks balljoint out. The installer tool is just a large sleeve tapered to fit balljoint and just drives it in flush. Havent checked the tool catalog lately,but think still available as a set like when I got mine years ago. Have heard of some using large sockets to drive in balljoint,BUT have to be careful that no damage to balljoint lip! Good luck
Old Nov 10, 2008 | 10:01 PM
bakford's Avatar
Default Ball joints
Thanks Tech!! One more question, Can the lower spindle come off or the whole strut? and do you need a spring compressor? Thanks for your time, AL
Old Nov 10, 2008 | 10:26 PM
Default Ball joints
Spring compressor not needed,but a good air impact is handy!!LOWER spindle? If talking about a-arm,just use blunt punch or car balljoint separator,rap sharply, and a-arm will come loose from balljoint.
Old Nov 10, 2008 | 10:44 PM
bakford's Avatar
Default Ball joints
Not the a-arm, the lower part with those 2 bolts, The top bolt holds the brake line. I was thinking of loosening those and sliding the lower half out. I don't know if it was under pressure. Thanks, AL
Old Nov 10, 2008 | 11:35 PM
  #15
Default Ball joints
remove strut cartridge nut at top,along with plastic bushings,remove tierod from strut,LEAN strut assy out,impact off nut,remove plate and spring,THEN can loosen cartridge bolts and slide cartridge out! OTHERS may do it different ,but this my way,then can remove strut separately. BUT not necessary to remove spring and cartridge IF just replacing ball joint! Can remove as an assembly.
Old Nov 11, 2008 | 06:58 PM
  #16
bakford's Avatar
Default Ball joints
Thanks all for your time, AL
STLyamwar
Jul 25, 2020 04:44 AM
89Lt250r
Sep 7, 2015 07:53 PM
toonces
Aug 13, 2015 12:40 PM
toonces
Aug 12, 2015 06:42 AM
musselmark
Jul 17, 2015 02:40 PM
