AWD and Speedometer don't work
Old Jan 6, 2015 | 07:59 PM
  #41
Insbroker2's Avatar
Thanks for talking me through it!
Old Jan 7, 2015 | 01:55 PM
  #42
Easy on that one. Check the right side brake caliper, there's a small aluminum cap that covers the hall effect sensor that sends the signal for the speed. It cam be dirty/mud covered,but 9 times out of 10 the hall effect sensor has shorted out if you don't have speed or mileage accumulation.Item #39.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Jan 8, 2015 | 07:08 PM
  #43
Insbroker2's Avatar
Checked the sensor, not dirty, odometer works, so I'll order the sensor. On the old note, I have and in forward, but not reverse. That's a problem in the snow. What do I check? Thanks?
Old Jan 8, 2015 | 07:38 PM
  #44
Check that all linkage ends are tight,not loose,plus the shift levers(belcranks) on the transmission are tight and haven't stripped the splines. If all of this is ok then place shifter in neutral, loosen the ball end 10mm lock nuts on the shift box levers. Remove the 10mm nuts holding the ball ends to the shift levers.Check how much play you have on the shift lever while in neutral. If excessive,adjustment may not help.
Turn the ball ends on the linkage shafts to where they drop straight into the levers with NO resistance.Tighten the lock nuts and replace the two 10 mm nuts. See if you have a positive reverse and forward. If not,then you may have to rebuild the shift box. Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Jan 8, 2015 | 08:45 PM
  #45
user493's Avatar
Moto Psycho
I thought the odometer wouldn't work if the hall effect sensor went out. Is it for speed only? If it is what does the odometer work off of?
Old Sep 17, 2015 | 03:45 AM
  #46
Weidis's Avatar
Hi, will this solution work on a 2007 model also? (Speedometer dead and not able to use AWD)
Old Sep 17, 2015 | 07:35 AM
  #47
If you want to have awd with out getting another speedo, jump the brown/white wire in the speedo harness connector to the brown wire. Awd should work.
Old Sep 17, 2015 | 12:47 PM
  #48
Weidis's Avatar
Thanks a lot! It worked perfectly
Old Sep 18, 2015 | 01:13 AM
  #49
At least you have awd and can concentrate on the speedo when you have the chance. May just be a wiring problem or if it's dead,there are a couple posts on folks tearing into theirs to try to save a few bucks.Here's one good post from a member named TaterTots. AWD and Speedometer don't work - Page 2 - ATVConnection.com ATV Enthusiast Community
Old Sep 18, 2015 | 01:40 AM
  #50
Weidis's Avatar
Thanks, I will look into this in the winter when the ATV is not being used. I believe it's humidity that has broken the speedo. Last year I took the speedo inside and let it dry, then it would light up and work for a short period of time. There is a small crack in it and it gets foggy on the inside. Drying it doesn't work anymore, it is totally dead. Hunting season starts next week and AWD is absolutely necessary
