Carb vs EFI
Old Nov 11, 2008 | 04:17 PM
  #21
Stoopidbot's Avatar
Default Carb vs EFI
I keep mine jetted for about 7500-10000. That seems to work good everywhere around here. You are right, the mountains up here are gorgeous.
Old Nov 11, 2008 | 04:28 PM
  #22
TLC's Avatar
TLC
Default Carb vs EFI
<div class="FTQUOTE"><begin quote>Originally posted by: crklapper
I HAVE A 2007 SPORTSMAN 500 EFI AND A 05 SPORTSMAN 500 CARBED AND SIDE BY SIDE THE EFI WILL LEAVE THE 05 EVEN WITH A PASSENGER</end quote></div>
Not from the 500 EFI I rode and the addition of EFI does cause the 500 Fuji more power if thats what your getting at.
There both rated at 35 HP.
If that was the case Polaris would have EFI on there sport ATVs not just there Utility ATVs alone.
Here is a 2008 450 Motocross shoot out and the only EFI bike (RM 450 Suzuki) is the weakest motor in the group.
450 Shootout.
EFI is not much of a performance advantage in that case.
<div class="FTQUOTE"><begin quote>Obviously the biggest update to the RM-Z450 is the motor and EFI. Did I notice a big difference? Not really. The bike did fire up easily, and it had a good amount of bottom and mid-range, but it doesn't have as much overrev as the other 450s.</end quote></div>
Efi has advantages but making a motor put out more HP is not one of them.
Old Nov 11, 2008 | 05:51 PM
  #23
robzilla23's Avatar
Default Carb vs EFI
I have a 2008 5oo sportsman Efi, and Buddy has 2008 sportsman carb. His consistently leaves my quad in the dust, no matter what I do. How can I fix this?
Old Nov 11, 2008 | 05:53 PM
  #24
Stoopidbot's Avatar
Default Carb vs EFI
I don't know how reliable my source is but I heard that carb has better throttle response. That's the difference.
Old Nov 11, 2008 | 06:09 PM
  #25
Doctorturbo's Avatar
GOT BOOST!
Default Carb vs EFI
<div class="FTQUOTE"><begin quote>Efi has advantages but making a motor put out more HP is not one of them. </end quote></div>
Very well said, and very true.
<div class="FTQUOTE"><begin quote>I have a 2008 5oo sportsman Efi, and Buddy has 2008 sportsman carb. His consistently leaves my quad in the dust, no matter what I do. How can I fix this? </end quote></div>
Start bolting parts on like a pipe. Or put a carb on. [img]i/expressions/face-icon-small-happy.gif[/img] Or start putting light tires on.
<div class="FTQUOTE"><begin quote>I don't know how reliable my source is but I heard that carb has better throttle response. That's the difference. </end quote></div>
The reason a carb will beat an EFI in the horesepower game is because of the intercooling effect it has on the intake tract of the engine. It's very, very close, but the carb will win out "IF" tuned razor sharp. The hotter it is, the more the advantage.
Old Nov 11, 2008 | 06:40 PM
  #26
robzilla23's Avatar
Default Carb vs EFI
I asked dealer about putting carb on mine, and they said it would be next to impossible. I don't see what would be so hard though.
Old Nov 11, 2008 | 07:04 PM
  #27
GOT BOOST!
Default Carb vs EFI
I was not very serious when I suggested you put a carb on your nice quad.
When I say the EFI and carb is close in power output, it means just that. They are SUPER close.
Your friend has some other big advantage. Weight is one of the biggest. Big tires just kill power!!!!!!! If he weighs 50 lbs less than you, that can be a big advantage.
Just enjoy your ride. You have a nice one!!!!
Old Nov 11, 2008 | 09:52 PM
  #28
Spdecat's Avatar
Default Carb vs EFI
Read these over and you decide , Myself Carb call the way .
I have a 06 ranger 500 efi got up this morning up hunting and nothing tested battery it's good are there any fuse links on the 06 ? i have checked connections on ingition and nothing can jump the soleniod and it will turn over but will not start thanks in advance for your help
All I have an 08-700 X2 and 2 of the wires have brokin at the solder joint inside of the plug for the T-BAP. I was able to remove the ruber O ring and slide it over the wire and push it back in and reseat the O ring to get a conection. I need to make it Perm. Question? have any of you had this yourself and what was the fix...replacement conector or more invalved? The unit is under worinty but I like to have a clue when I take it in. The folks are super at the dealership I use and they will order in advance if I know what is needed and they will fix it as i stand by, as I live 65 miles away and hate to drop it off and then go back to P/U. Any help ....I thank you in advance!!!
I had the same problem on my '05 700, it ended up being thr ECM which was recalled twice already and it was the defective ECM's on 2 '05 500 also. Flashes hot and or fan stay's on.
We took our brand new Sportsman 400 for my wife and my new 500 EFI out for the first time today. We had a great time and the 400 ran great all day. My 500 was fine at first and then ran good except it would not idle. Very frustrating especially the downhills and hard on the starter too. I wish Polaris would have put the starter button over by the left hand, so you could hold the brake and hit the starter with the same hand.
So when I got home, I read the book and like I suspected with EFI, it says if the idle is unsatisfacory, see your Polaris dealer.
However I tightened up the slack in the throttle cable to where it would idle now. I think. It was touchy and had to do it a few times because once I thought I had it, and the next time I started it , it raced too high, or it was too low again but it seems OK now.
But, did I do it wrong? This is my first ATV with fuel injection and being brand new, I don't want it jury rigged. Is this the way the dealer would set the idle?
One other thing that happened once and scared me because the little 400 would have had a hard time (to say the least) pulling me out of there.
Went to start the 500 after repeatedly stalling , pulled the brake and it did nothing. Put it in neutral, it still did nothing but the key was coming on cause the IP came on, just no starter engagement.
After trying it several times, turning he key on and off, it just started cranking, like nothing was wrong. Only did that, just that one time. Any body have any ideas or had this happen before?
Other than these things I really liked it alot better than I liked my '08 Grizzly 450. Altho I never had any problem with the Yammie except the rear seal.
I sure was wishing I had 3 hands today tho.
One to hold the brake; one to turn the key; and one more to give it a little gas , so it would start.
Hey guys,
Im havng running issues with my 500 efi. the motor tends to just cut off and shut down when it wants. you can start it right back up and 30 seconds later it cuts off again.
I have done some reading and its appearant that My t-bap harness may have went south on me.
can some one tell me where this little harness/sensor is located. i want to check for and frayed or broken harnesses. Ive heard there is a replacement harness for this. How involved is it to install? I havent checked for any codes yet. will do so when I get home. It positvely cant be corroded for the bike has never seen any water or mud. Its in immacultent condition.
Does anyone know the price of one of these? and also a part #.
Thanks in advance for your help.,
hey guys,
after coming out of the woods today my 500 sportsman cut off for no reason. as it sputtered off the check engine light come on. she would start right back up and cut off 30 seconds later.
it checked the diagnostics and the battery read 11.7. is this too low?
what else could be wrong? is there any plugs that may have come loose. if so what do i need to check? If i can recall some wires on a sensor can fray causing this problem
this quad is in mint condition so i cant imagine what would be wrong with it
2007 Polaris Sportsman 500 EFI New Mossy Oak Camo Edition.
hey guys,
im trying to get the screen to throw a code at me for my bike just cuts off when it wants.
i called my dealer and he knew exactly what my problem was (tbap harness) he said for 125$ it can be fixed. i guess ill have it done by them..
The dealer first thought it was the t-bap harness, then the mechanic told me to try and wiggle the wires on the throttle position harness first, and that's what it was. The orange wire (if I remember correctly) goes from the tps to the t-bap. I was getting a code 45 (Barometric Pressure/Manifold Air Pressure Sensor Low). Sure enough it was the harness on the throttle body and not the harness on the air box. When I messed with the wires, the check engine light would go on and off. I was told the problem was Polaris made the harness too short and the wires would vibrate loose or break. The harness for the t-bap(air box) was about $28, and the tps harness(throttle body) was around $36. It's an easy fix no matter what harness your need to replace. The diagnostic mode while in park and turning the key 3 times is the EFI diagnostic mode, to get flash codes when the check engine light is on. The neutral / reverse override diagnostic mode just gives you general info; battery voltage level, AWD Diagnostic Screen, Gear Circuit Diagnostic Screen, & Programmable service interval. Have a good one!
Does anyone have access to the diagnostic tree to diagnose codes, I have a 04 700 EFI Sportsman. The service manual I have doesn't have the info, says see the dealer. I have the codes and descriptions, just how to figure out what is wrong 41 Air Temp Sensor
Old Nov 11, 2008 | 10:34 PM
  #29
max49's Avatar
Default Carb vs EFI
I've got the 0'8 500 EFI and my wife has her 400HO. She loves it, and the little sucker will go too. We live in CO so it's jetted with a 145 main. We've been to Moab, about 4000' elevation, and to the top of Red Cone@ 12800' elevation, and every thing in between.
Obviously it can't be jetted perfect for all these elevation changes, but it did darn good.
EFI is nice but I would'nt rule out the little 455 because it has a carb.
Old Nov 13, 2008 | 09:03 AM
  #30
user493's Avatar
Moto Psycho
Default Carb vs EFI
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
450 Shootout.
Efi has advantages but making a motor put out more HP is not one of them.</end quote></div>
EFI has advantages including more power, at least on the Sportsman 500s. It's 1.5 HP more than the carb H.O. They aren't rated the same power.
