Problem with radiator. need help badly
Old Nov 12, 2008 | 08:05 PM
polarisboy20's Avatar
Default Problem with radiator. need help badly
i was riding it and it has new antifreeze and i was riding it and the overheat light came on! and i think that the radiator is clogged with dust and mud! but not sure!!!
NEED HELP BAD!!!
Old Nov 12, 2008 | 08:31 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Take it from me............Check the back of the rad where the fan is .......The fins get plugged there and no air will flow through it.........
When the fan comes on it draws the air from the front and sucks it through blowing the warm air towards the rider/engine.
Make sure it is flushed really good....
Remember too.......If using a pressure washer.......The fins may get bent over or damaged........Keep your distance............Caper.........
Old Nov 12, 2008 | 08:46 PM
ok how do you flush out the radiator???? jw
Old Nov 12, 2008 | 08:50 PM
Garden hose and hand nozzle works good.............Just flush it good and you should see light through it when clean....If really bad you may want to take the fan ,rack,and shroud off to gain access......
I use a flashlight and look to see the light between the cooling fins..........Caper............
Old Nov 12, 2008 | 08:53 PM
ok so do i have to take the radiator off in order to take the fan off???
Old Nov 12, 2008 | 08:56 PM
upnort's Avatar
No if like mine there are 4 bolts (10mm I think)and the plug for the fan come off.
Old Nov 12, 2008 | 08:57 PM
I would try to flush it out on without taking anything off first and then go from there...........My sportsman comes clean after flushing it out ..........installed.........Caper..........
Old Nov 12, 2008 | 09:02 PM
ok so just run a hose through the radiator first and then go to the fan???
Old Nov 13, 2008 | 08:28 PM
Did you get it clean?
.....Caper.........
Old Nov 13, 2008 | 08:33 PM
i ran a water hose through the radiator and alot of mud came out! is that what i should have done????
