Two winch capability?
Old Nov 19, 2008 | 08:41 PM
user493's Avatar
Moto Psycho
Default Two winch capability?
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
Lots of people have wrenches on the front and back at once, the quick release are not so quick when your stuck in a waist deep swamp hole and have to get off the ATV to swap ends.</end quote></div>
You have to get off anyway to spool out your cable and hook it up. I kept my winch on the back and the quick release bumper on the front. It balanced out great that way. I could swap the bumper and winch out in under half a minute.
My multi-mount had what I believe were 6-gauge wires. They were as thick as jumper cables. The quick connect plugs are the same exact design as the plugs on fork truck batteries, but a little smaller since the ATV battery doesn't weigh 2-3 tons and put out 36v. The connectors were mounted about even with the top of the wheels and rubber plugs kept the crud out of them when the cable wasn't plugged in.
Warn quit making one ATV model but still makes 2 others and makes them for trucks too. Here's a good look at the old ATV model. http://www.warn.com/atv/winches/A2500MultiMount.shtml It mounts in the trailer receiver but the Polaris Multi-mount was up a lot higher near the racks. It was the best winch mount ever made IMO.
Old Nov 20, 2008 | 01:33 PM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>You have to get off anyway to spool out your cable and hook it up.</end quote></div>
Yes I guess there no way around not getting off.[img]i/expressions/face-icon-small-blush.gif[/img]
Old Nov 20, 2008 | 02:21 PM
HIGHOCTANE's Avatar
Yes I guess there no way around not getting off.[img][/img]</end quote></div>
Unless you have someone willing to do it for you,lol.
Old Nov 20, 2008 | 02:36 PM
Groovy's Avatar
I did a quick sketch over lunch of the trailer in mind... just the side profile. When I have a bit more time I'll do up a 3D model.
The mast will be reinforced on 3 sides (front, right & left using similar idea as front angular support) Any ideas / criticism welcome.
http://i12.photobucket.com/alb...ion/trailerModel1.jpg
Old Nov 20, 2008 | 02:39 PM
  #15
Groovy's Avatar
In hindsight I should have added the additional bunk support typically run between axles and frame. OOPs.
Old Nov 20, 2008 | 05:06 PM
  #16
700 sportsman's Avatar
looks like a pretty nice drawing, and looks like it would work pretty slick
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
