polaris xpress 400 backfiring
Old Nov 19, 2008 | 02:17 PM
ryru016's Avatar
Default polaris xpress 400 backfiring
just rebuilt the motor and ran fine for a while.
now after getting warm it will revup all the way and not go down until you choke and kill it.
it also started backfiring quite often.
i checked the needle and seat and seems to b sealing
what else could b happening
Old Nov 19, 2008 | 09:31 PM
Carb slide sticking? Also did you replace crank seals?
Old Nov 19, 2008 | 11:00 PM
canadapolaris's Avatar
the same thing happened to my express 300 and i just changed the crank seals and then after that it worked fine
Old Nov 21, 2008 | 01:44 AM
ryru016's Avatar
i did replace the crank seals when i rebuilt the moter
and slide is free first thing i checked.
when it the seals or reeds they say that it raps out consistantly.
idk
but
it backfirse bad and done it since done the motor and constantly gets worse.
Old Nov 21, 2008 | 07:15 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if the engine is sucking air say from a bad crank seal it will do what you described. not the safest thing to do but if you sprayed starting fluid or maybe carb cleaner would work as well down around the crank seal w/ the engine running and if it idles up then the seal is bad. imo.
Old Nov 21, 2008 | 12:55 PM
ryru016's Avatar
ok
ill try that and see what happens
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Mar 6, 2018 06:53 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
blpersinger
Jul 15, 2015 09:56 PM
