Big Horn Tires
Old Nov 24, 2008 | 10:31 PM
coacho's Avatar
Default Big Horn Tires
What is the Differents between the regular Big Horn tires and the new Big Horn 2.0
Old Nov 24, 2008 | 10:43 PM
JCDEYO25's Avatar
The newer ones are weigh less....
Old Nov 25, 2008 | 07:14 PM
DCT's Avatar
DCT
Banned
Also, they are a bit narrower, and depending on what size you get, there is less tread height. There may be other differences that are not noticeable. However, these are probably the tires I'm going to get.
The weight difference is significant.
Old Nov 25, 2008 | 10:14 PM
quad 4's Avatar
the new 2.0 is similar but not the same tread....you could see it well on maxxis site...if you compare....[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 26, 2008 | 11:32 PM
Kcolg's Avatar
IF getting the 25" tire the tread depth difference is pretty signficant. 28/32" tread depth on the old Bighorns and 23/32" on the 2.0 version. The other tire sizes I think are still the same at 25/32" tread depth.
Old Nov 26, 2008 | 11:38 PM
DCT's Avatar
DCT
Banned
<div class="FTQUOTE"><begin quote>Originally posted by: Kcolg
IF getting the 25" tire the tread depth difference is pretty signficant. 28/32" tread depth on the old Bighorns and 23/32" on the 2.0 version. The other tire sizes I think are still the same at 25/32" tread depth.</end quote></div>
Yep, I plan on getting the 26". No difference in tread depth.
Old Nov 27, 2008 | 01:00 AM
RticKwad's Avatar
Runs Stealth!
I hear this is the better "ROCK" type tire?
Regards,
R'
Old Nov 27, 2008 | 03:20 PM
coacho's Avatar
so the 1st ones had to be balanced
Old Nov 27, 2008 | 04:00 PM
quad 4's Avatar
I got regular BIGHORN and the TERRACROSS. The regular bighorn is good for dry condition, lite mud and REALLY rock proof.....Running these tire is like having another suspension.
The new 2.0...I bet the are much better in wet condition and for soft soil and snow...witch the regular are bad...
Old Nov 27, 2008 | 04:07 PM
DCT's Avatar
DCT
Banned
<div class="FTQUOTE"><begin quote>Originally posted by: quad 4
The new 2.0...I bet the are much better in wet condition and for soft soil and snow...witch the regular are bad...</end quote></div>
quad,
Why do you think the 2.0 would be better snow than the regular Bighorns? They have essentially the same tread design. They both are 6 ply radials, unless you have some of the old 25" Bighorns that were bias ply.
Just curious.
