Polaris Sportsman bogs down with air box installed
Old Jul 11, 2018 | 08:40 PM
  #71
Pyramid Inn's Avatar
just fixed my 2000 sportsman 500 bog; it would not rev out with airtube on it with no lid on it either, I would get quarter throttle then it would miss and breakup, all I did exactly was put it back together airbox lid on filter in everything tight and bam runs like a champ, don't know why it don't matter I'm up and running hope this helps.
Old Aug 13, 2020 | 03:11 PM
  #72
Tom Mills's Avatar
Originally Posted by Pan64FL
Working on a 1998 Polaris Sportsman 500. This thing had a couple of unusual problems that baffled a few good techs. Got the starting problem, previously posted, repaired and now starts like new.
I tested this ATV with the air box removed, ran like a scalded dog at high speed, pulled some impressive wheel stands, awesome power and idled like a Cadillac. Put everything back together and it bogs badly in neutral or in gear, won't rev up.
Removed air filter, same problem. Removed air box, ran like new again.
Replaced the carb with a direct factory replacement. Float level correct, choke and throttle cables adjusted to specs. I removed the air intake tube from the air box, checked for obstructions, there were none. About 2-1/2" on the filter side and 1-1/2" on the carburetor side. I can rev the motor to 3k or 4k RPM's, slip the air intake tube over the carb air inlet and the motor practically dies. Remove the intake tube and the RPM's pick back up almost immediately. The original carburetor did the same thing and was replaced because of this.
Is it possible for jetting to be this far off on a factory replacement carburetor?
Anyone have any ideas?
Any luck on getting a fix for this
Old Sep 8, 2020 | 02:24 PM
  #73
Shawn Murphy's Avatar
Originally Posted by murphyismyname
I have a similar issue with my 97 Magnum 425. The only difference is that if I put my hand partially over the air intake hole after everything is put together, it will rev up again. Does anyone else have the same thing happen? Its like its just getting too much air. As long as I just block a little bit of the air intake hose, it will rev up and run just fine...
Same issue. 2000 sportsman 335. If I restrict intake orifice at airfilter it revs up great. I've tried everything
Old Oct 5, 2021 | 07:55 PM
  #74
Blet's Avatar
Default Help
I’m having the same issue with my 02 magnum 325. Changed fuel lines, carb, throttle cable, and air filter. With the air box lid off it throttles up. With it on it bogs over 1/2 throttle.
Does that mean the air box is leaking, or stopped up?
Im at a loss
thanks
Old Jan 9, 2023 | 09:25 PM
  #75
Sportsman 400 2005's Avatar
Default If you want a short tremperly fix take off the air box cover
take
Old Mar 2, 2023 | 06:24 PM
  #76
Mark231's Avatar
Default Magnum 325 bogging.
Weekend Warrior did you figure out your issue with your Polaris Magnum 325. I am having the exact same issue.
Thanks.
Mark
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
