Glacier plow lift bar
Old Dec 30, 2008 | 10:27 AM
  #21
DCT's Avatar
DCT
Banned
Default Glacier plow lift bar
<div class="FTQUOTE"><begin quote>Originally posted by: *5 J's*
I have noted any flexing in the mount - and I have hit a bank VERY hard. That what broke my winch hook, lift bar, and gouged my brush guard.
</end quote></div>
Excellent! Sounds like the Moose mount may be more rugged than the Polaris mount.
Can you do me a big favor... the next time you crawl underneath the front of the bike, can you measure how thick the mount is where it connects underneath past the drain plugs. I will double check the Polaris mount, but I bet it's not more than 1/8" thick.
Yea, my fairlead was chewed up a bit by the steel cable. I got a new machined fairlead for the synthetic rope.
Thanks.
Old Dec 30, 2008 | 10:37 AM
  #22
*5 J's*'s Avatar
Will do
<div class="FTQUOTE"><begin quote>Originally posted by: DCT
Thanks.</end quote></div>
Old Dec 30, 2008 | 05:39 PM
  #23
DCT's Avatar
DCT
Banned
Thanks man... appreciate it!
Old Jan 9, 2009 | 03:18 PM
  #24
*5 J's*'s Avatar
</end quote></div>
DCT - I want to mic it to check for sure but haven't got a chance yet. While pondering the spring replacement job - I did take a look. I would guess it is 1/8 plate. Didn't quite look 3/16.
Old Jan 9, 2009 | 06:51 PM
  #25
loaderboy's Avatar
you guys sure got some great ideas, i just went out to my new glacier 2 and removed the winch bar and found a small clevis that fits perfect i removed the clevis bolt and added a bolt long enough to go through the clevis and the mount. works perfectly. by the way i have it mounted to a xp 550 so the winch is mounted low i raised it until the blade hit the stops and still had plenty of clearance between the plow and the grill. i dont have a brush guard installed though. happy trails!
Old Jan 9, 2009 | 06:58 PM
  #26
DCT's Avatar
DCT
Banned
DCT - I want to mic it to check for sure but haven't got a chance yet. While pondering the spring replacement job - I did take a look. I would guess it is 1/8 plate. Didn't quite look 3/16.</end quote></div>
Thanks *5 J's*,
Sounds like it's about the same thickness as the Polaris mount. Sure hope it is built to better specs with stronger steel and better hardware than the Polaris.
Thanks again, and good luck with the mount and plow system.
Old Jan 9, 2009 | 10:34 PM
  #27
rancher55's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: loaderboy
you guys sure got some great ideas, i just went out to my new glacier 2 and removed the winch bar and found a small clevis that fits perfect i removed the clevis bolt and added a bolt long enough to go through the clevis and the mount. works perfectly. by the way i have it mounted to a xp 550 so the winch is mounted low i raised it until the blade hit the stops and still had plenty of clearance between the plow and the grill. i dont have a brush guard installed though. happy trails!</end quote></div>
I'm glad it worked for you loaderboy!
I like it much better with another foot of cable out (without that damn bar)!LOL![img]i/expressions/face-icon-small-smile.gif[/img]
shimanok2
Jan 29, 2016 07:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
kampswas
Sep 23, 2015 05:05 AM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
