starter gear is retreating
Old Jan 1, 2009 | 06:57 PM
eggenz7's Avatar
Default starter gear is retreating
is there any teeth missing on the flywheel? the voltage drop is right in the range that its suppse to be.
Old Jan 6, 2009 | 07:00 AM
rfisher's Avatar
Hi
well, the fly wheel teeth are OK.
I tested the battery with special tool and it is in good condition.
It seems that the charging is fine, if the battery reads OK after a year.
My conclusion is that is is the starter motor, I will open up the starter motor
and will test is by the book.
will update soon...
Thanks
Ron
Old Jan 13, 2009 | 03:59 PM
rfisher's Avatar
solution~~
Hello,
I did some tests and I think that the problem is certainty the starter motor.
I will have to put in another motor in order to be sure.
Anyway I did find a way to make it work, I tryed to put my old starter gear in order to eliminate the gear, I was very surprised that the problem was solved when the old gear was in place.
It appears that the old gear weight spring was missing and it add some friction to the retreat of the gear, when the engine fires it push the gear back to place.
I have try this several times and it seems to be fine.
this is only temprarly. I will order a new starter motor
Thanks
Ron
ghost civic
Jan 15, 2020 07:43 AM
ScopeZ_
Jul 28, 2015 01:44 AM
ghost civic
Jul 19, 2015 10:13 AM
Chuck188
Jul 17, 2015 02:45 PM
ghost civic
Jul 15, 2015 10:48 PM
