Installing a winch
Old Jan 21, 2009 | 10:15 PM
turbo777's Avatar
Default Installing a winch
Ok back to the shop...
Thanks Tyler
Old Jan 21, 2009 | 10:19 PM
700 sportsman's Avatar
have fun
Old Jan 21, 2009 | 11:47 PM
chuck_raduenz's Avatar
yes you need a ign sorce for the handel bar switch. mine is red and my 500ho carb there is 2 orange/white wires under the front nose cone.
if you follow the fuse block wire/loom you can see where i connected mine.
Old Jan 22, 2009 | 05:47 AM
hobbles's Avatar
Mornin turbo777
chuck_raduenz is right, you will have a wire in the pod that will become hot when you turn the key on. It will be loose and you can find it with a tester. Sounds like your good to go.
Old Jan 22, 2009 | 06:53 AM
  #15
stendori's Avatar
Super Quad Patrol
I'm watching you!
the wire in the pod is a single wire(red or orange) w/ a rubber end over it which has power when the key is turned on.
Old Jan 22, 2009 | 07:12 AM
  #16
Wow my memory has failed me yet again
Sorry Turbo and thanks for the correction guys
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
2many2ride
Sep 27, 2015 04:35 AM
cboler9
Sep 24, 2015 08:35 PM
