TIRE SLIME
Old Jan 21, 2009 | 09:53 PM
HIGHOCTANE's Avatar
Default TIRE SLIME
Use a spray bottle with a little dish soap and water..air it up..you can safely go quite a bit above operating pressure,but 10 psi or so will be plenty to give you ample time to hunt for it..spray it down all over..including the valve stem and beads and look for the bubbles..
If it is in the tread area plug it..plug kits are cheap and easy..just follow the directions..
If it is in the bead we can tell you how to resolve that also..it isn't that hard..but I don't want to just give you a one line instruction for safelty reasons..
Alex G.
Sep 11, 2017 11:38 PM
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
