2001 Polaris sportsman 500HO
Old Jan 28, 2009 | 11:49 AM
TLC's Avatar
TLC
Default 2001 Polaris sportsman 500HO
<div class="FTQUOTE"><begin quote>Originally posted by: nacman34
I need just the shock, I guess, since I can't find the bushings that go in them, top and bottom. That's what went out on them the shocks are fine other wise as far as I can tell no leaks or anything. If you look at the parts list it has a diff part number for 3/1/01 before and after that date.</end quote></div>
Here is Polaris site that cross references Polaris parts for other models. http://parts.polarisind.com/Assemblies.asp
Shock fits from 2001-2009 on many models.
Maybe the shock was changed in someway but the new replacement shocks still have the same dimensions in every way.
You scroll right and click on "Usage". Its weired in many case even though the Part # is different on many parts the parts are still the same. Recoil starters fo example. The rope Reel for my 2001 has a differnt Part number than a 500 Polris Indy but it works.
Old Jan 28, 2009 | 12:41 PM
nacman34's Avatar
Ok I saw that site but it was wierd Its had to understand but ill just try and get a pair if they don't work ill just take them back. All the vin says is year model 02magnum500 but thanks for the reply.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Coryco
Jul 6, 2015 07:30 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
