polaris 500
Old Feb 5, 2009 | 11:58 AM
TLC's Avatar
TLC
Default polaris 500
<div class="FTQUOTE"><begin quote>I think that could of been my problem use 5w30 for oil as the book that came with quad says too do I think next time I'll use 0w thanks </end quote></div>
Thats odd because Polaris OEM oil is rated at 0W-40 there new oil is rated at 2W-50 I think. 2W is still a thin cold start oil.
Plus Polaris Oil is Full synthetic oil. a 5w weigh that is "conventional" is a worst choice than 5w Full synthetic.
I use Amsoil 0W-40 (Full Synthetic also) if I feel like not driving to the dealer.
Do not buy the synthetic Blend crap,they have 10-20% synthetic oil in them at most.
Old Feb 8, 2009 | 01:02 PM
bigter's Avatar
Default polaris 500
[img]i/expressions/face-icon-small-frown.gif[/img]I found the problem and for sure its the camshaft,nothing left of the exhast lobe thanks for the help
Old Feb 13, 2009 | 11:27 PM
goodblasson's Avatar
Default polaris 500
Can you please post a picture. PLease.
Old Feb 14, 2009 | 08:22 AM
drlang's Avatar
Default polaris 500
The 500HO cam will go right into your non HO 500. Make sure you put new cam followers in. Good luck Doc
Old Feb 14, 2009 | 08:52 AM
  #15
DCT's Avatar
DCT
Banned
Default polaris 500
A lot of things can cause backfiring...
For sure, the cam lobes could be worn.
Valves could need adjusting.
Bad spark plug.
Almost anything in the ignition system... like a bad coil, spark plug wire.. etc.
Faulty wiring.
Running lean.
Even a leak in the exhaust system.
If your getting good spark to the plug, and the plug is fine, you can eliminate most of the electrical stuff.
Old Feb 15, 2009 | 12:31 PM
  #16
bigter's Avatar
Default polaris 500
I don't have a manual so can someone tell me what side the camshaft comes out the left or right.Do I have to worry about chain guides will they come togther when I take can out.if anyone knows what to set the vavles to would help thanks
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
