Polaris 2002 500 sportsman starter problems.
Old Feb 18, 2009 | 11:17 AM
manxman's Avatar
Default Polaris 2002 500 sportsman starter problems.
Hey guys I was having trouble with starting my sportsman .I took the cover of to get at the bendix and replace it there was a spring broken .I cleaned everything and took the pull cord assembly apart and fixed that so at least I can pull start it.Now the starter is not spinning it just clicks on the opposite side.I think it is the starter solenoid switch am I on the right track.There is also a new battery in it I was thinking I might try the battery out of the mower just curious as to if the new battery is strong enough to turn the starter.
Old Feb 18, 2009 | 12:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
w/ the key on just jump the solenoide and if the starter works you know its the solenoide thats bad instead of the starter.
Old Feb 18, 2009 | 01:26 PM
Kerbbirds's Avatar
Check the connections at the selenoid, I've seen the nuts behind the battery cables loose and coroded not making good connection.
nature violator
Jul 3, 2015 08:40 PM
bikedad3
Jun 29, 2015 08:58 AM
gfl0224
Jun 27, 2015 06:52 PM
Ragtop
Jun 27, 2015 03:04 AM
Dakosk
Jun 6, 2015 05:37 PM
