HO front end to soft for me...
Old Feb 11, 2001 | 09:07 PM
argo's Avatar
I would try the rubber inserts first. They are easy to install and do a good job for recreational riding at a minimal cost. If you like to get big air I would agree with above buy the heavy duty spring, or progressive unit. If you have to go to the Works strut or Fox strut you may be riding the wrong machine.
Keep your tires on the ground, and the mud out of your face.
Old Feb 11, 2001 | 09:11 PM
SportzMann's Avatar
I have the rubber inserts from Polaris. Thet did help...slightly. Still bottoms out. I'm going Progressive.
Old Feb 11, 2001 | 10:25 PM
Xplor's Avatar
I would do all of the above except for the heavier springs. I put them on my Xplorer and ride was sooooo bumpy and rough. I then took them off about a month later. Works, Fox, rubber spacers, shave the interior of the fenders or progressive...all good choices.
Old Feb 12, 2001 | 01:33 AM
Jenks's Avatar
Thanks everyone for your suggestions. I knew I could get a lot of good ideas from this forum. I will check into them all. I am leaning toward the HD springs but if they don't work I have plenty other ideas to try. Thanks again.
Old Feb 12, 2001 | 08:51 PM
  #15
Odin's Avatar
You need the HD springs. If you read the parts book the Magnum, Xplorer, and Sportsman all have the same front spring weight 67-110. Now the Sportsman is between 50-113 pounds heavier than those other quads.
I have a 2001 HO I have added the 101# front and the 140# rear. The stock springs did NOT hold up for my riding style and weight load. I use a fuel pack on the front that is about 35 pounds of gas. I have the polaris box on the back with about 45 pounds of gear and I weigh 320 pounds. With the heavy springs on my HO it rides like stock.
I tried the rubber donuts for me it was a waste of 12 dollars.
Good luck.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
