SP400 not charging
Old Feb 23, 2009 | 02:31 AM
sprtsmnfan's Avatar
Default SP400 not charging
2001 SP400
Already got a new battery.
Voltage reading drops off after quad is running. Eventually fans, lights, AWD die.
Quad has been through heck. Well maintained but a rough life. Can't blame it for needing this fix. Magneto system new to me. What is replacement cost? Where do i find replacement instructions? While i'm doing this...Are there upgrades? (could always use more juice)
Old Feb 23, 2009 | 08:15 AM
Check that regulator/rectifier located at very front of machine has all 4 wires connected(sometimes one or more can pull loose) should have yellow,yel/brn,red(main power wire) brown. Could be cause of charging problem. Good luck
Old Feb 24, 2009 | 04:13 AM
sprtsmnfan's Avatar
Thanks for the reply..
Where is this regulator located? Under front hood near radiator fill cap???
Old Feb 24, 2009 | 04:18 AM
In front of radiator on left side behind bumper guard towards top.
Old Mar 2, 2009 | 02:57 AM
sprtsmnfan's Avatar
OPT,
Thanks a ton. U were 100% correct. One of the wires was corroded and broke loose. Ten min with a solder gun and some shrink tubing and I had the machine charging at 14.5 like its supposed to. U saved me tons of $$$. Can't begin to tell ya how much i appreciate the help.
SprtsMNFan
Old Mar 2, 2009 | 05:40 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its a common issue w/ bikes that old. glad it was an easy fix.
Old Mar 3, 2009 | 04:44 PM
kaptn12's Avatar
yes i am having the same exact problem with my bike but mine is a 1993 sportsman 350. Could this be my problem
Old Mar 3, 2009 | 09:28 PM
<div class="FTQUOTE"><begin quote>Originally posted by: kaptn12
yes i am having the same exact problem with my bike but mine is a 1993 sportsman 350. Could this be my problem[/
Very possible! located under front panel down from cdi
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
zPuls3
Sep 12, 2015 08:54 AM
