Trailblazer with a noisy rear end
on the outside or the inside of the housing? to remove the case pull the secondary clutch and the 3 bolts that hold the clutch cover backplate. go underneath and remove the two bolts that bolt the case to the frame (probably a spacer with those bolts too) the at the rear left side of the case is a long bolt that is pushed up against the frame, remove it also. remove the drive chain and the shifter rod and the wire harness thats plugged in.
i have it tore down partialy now.. i have the chain,rear fender, breather box,clutch housing cover and the rear pulley taht the rubber belt rides on, what's next????
