rebuild on 92 trailboss
Old Mar 8, 2009 | 06:51 PM
rockout's Avatar
Default rebuild on 92 trailboss
tore the trailboss 250 down this afternoon. everything went as well as expected. exhaust was a little hard to break loose. after getting it all apart, i ended up breaking one of the head studs off while removing. ended up drilling and am going to install a thread insert. only small question i have is- as far as i know, stock bore is 72mm. i measure the piston and cylinder and read 72mm, but the piston has a marking of 5w on the top. does anyone recognize this marking? seems like if it stood for .50 over, i would have a much larger reading on the bore and piston. any advise? it is going to the machine shop and i will let him measure too.
Old Mar 8, 2009 | 09:07 PM
ftwflh's Avatar
Mic the piston then measure the piston to cylinder clearance.Then go the next size to get .002 clearance.
Old Mar 11, 2009 | 08:04 AM
rockout's Avatar
took the cylinder to the shop monday. he measured stock bore also. he called tuesday morning with great news-all done. picked everything up and had her fired up in a couple of hours. what a differance. starts right up(no extended cranking or playing with choke). it idles!!!!! down pouring rain and cold, so no test drive. may take it out wednesday.
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
