wont shift into high gear 2005 700 polaris
Old Mar 13, 2009 | 04:56 PM
mnickels76's Avatar
Default wont shift into high gear 2005 700 polaris
Hello! I have a 2005 polaris 700 4wheeler with 4wd and it wont shift into hi gear. All other gears work fine. I have tried hi gear in both 2wd and 4wd and it wont shift to hi in either. Can anybody help? Thank you!
Old Mar 13, 2009 | 05:21 PM
eggenz7's Avatar
do you mean it the shifter itself wont let you get past low or the shifter moves into the correct position but the wheels dont spin when you try to go? does it make any noises when you try to shift it? any problems at all with other gears? 4wd act funny sometimes?
when you try to get somebody to daignose something over the net you gotta give as much info as you know about it. its kinda like somebody coming on and saying "OMG MY WHEELER WONT START SUMBUDY TELL ME WHAT IS WRONG!!!" dont really have any idea where to start giving you clues to. not trying to be a smart a$$ but just need some more clarification.
Old Mar 13, 2009 | 05:49 PM
mnickels76's Avatar
the lever will not move past low. all linkage is fine. No noises. all other gears are fine. 4wd acts normal.
Old Mar 13, 2009 | 09:36 PM
<div class="FTQUOTE"><begin quote>Originally posted by: mnickels76
Hello! I have a 2005 polaris 700 4wheeler with 4wd and it wont shift into hi gear. All other gears work fine. I have tried hi gear in both 2wd and 4wd and it wont shift to hi in either. Can anybody help? Thank you!</end quote></div>
Make sure spring is hooked up to foot brake and trans lockout plug. When brake applied it pulls down lockout and allows you to shift into hi range and also park. Only used a couple years!
Trade3
Ask the Editor
Jun 21, 2015 10:30 PM
Jun 10, 2015 11:20 PM
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
Fullblast
May 26, 2015 12:38 AM
