polaris 500 2001 wont rev
Old Mar 19, 2009 | 04:29 PM
go fish's Avatar
Default polaris 500 2001 wont rev
since i posted my prob . the replys i have got are telling me to check the exaust lobe on the cam to see if there is any wear on it . i havent done that yet but i will try to keep you posed on my progress
Old Mar 20, 2009 | 10:14 PM
silverbullit's Avatar
I went through identical symptoms last season, very frustrating, but I would bet my left nut that it is your exhaust lobe on your cam. Mine came on very suddenly, and after reading through this forum it was a chronic problem in the 01 HO's. When mine was removed, I was shocked to see the middle lobe (exhaust) almost worn smooth. Apparently they have rectified the problem with the replacement parts. Mine also requred a new rocker arm. But it's all good now, and it's nice to have that power restored, feels like new again!
Old Mar 22, 2009 | 09:16 PM
Viper02's Avatar
I just got done going through the same thing with my 04 700. I know you said you cleaned the carb, but did you pull the diaphram out and clean the slide? The top of the carb was wet and the slide was filthy. Once I cleaned that and replaced the plugs, I was good to go. Replace the fuel filter that filters air directly to carb. It's located between the two snorkels between the tank and seat.
Old Mar 23, 2009 | 09:41 PM
go fish's Avatar
thanks for the info i will check that to
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
