Magnum Overheating
Old Mar 26, 2009 | 09:24 AM
Kerbmonster's Avatar
Default Magnum Overheating
u can test the sensor, can't remember what the resistance specs are off the top of my head, but if u put the sensor in hot water and check the resistance as it gets hotter.
Old Mar 26, 2009 | 09:32 AM
Shallow_Hal's Avatar
anywhere i can get these specs?? this seems to me like a hail mary! i really think the light is working, but i will do anything!!
Old Mar 26, 2009 | 09:33 AM
a service manual will tell u the specs i'm just not close to my manual, otherwise i'd look it up for u. it would be the same spec for a 500, same engine basically
Old Mar 26, 2009 | 09:38 AM
thanks for the help.. if you can post the specs when u get near the manual, i would appreciate it. i bought a manual two weeks ago but they cancelled my order.. it wasn't in stock..
if it is not the sensor.. what will it be???????
Old Mar 26, 2009 | 09:40 AM
  #15
when i get to the manual, i'll get the specs, if it's not the sensor, i would check and make sure u have coolant flowing into the motor, then maybe it's the water pump
Old Mar 26, 2009 | 09:43 AM
  #16
TLC's Avatar
TLC
If you have coolant flow and a clean rad with a working fan it has to be just a bad sensor .
Old Mar 26, 2009 | 10:13 AM
  #17
thanks for all the help.. but while i have an audience.. after i fix the light/overheating problem i am going to put some tires and rims on it. i have a good deal for some 27 inch mudzillas and some itp rims. i was wondering if that is too large of a tire for such an old 4 wheeler. and do all rims fit all atvs (is the lug pattern the same?)
i don't want to cause other problems (like with the axle) or parts???
Old Mar 26, 2009 | 10:28 AM
  #18
TLC's Avatar
TLC
Ok ,after looking at my manual there are other things you can check. Is the coolant system bleed properly so there are no air in system ,and the rad cap can wear out, it suppose to control the amount of pressure in the cooling system, the cap should sustain 13psi relief for 5 minutes or longer.
All my manual says about the hot light sensor is that it comes on at 221 F or 105 C.
Old Mar 26, 2009 | 10:32 AM
  #19
how do i check that?
Old Mar 26, 2009 | 10:38 AM
  #20
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: Shallow_Hal
how do i check that?</end quote></div>
The manual (Clymer) just says have the cap pessure tested it does not say how, I would bring the cap to a automotive rad shop and ask if they can do it.
