Magnum Overheating
Old Mar 26, 2009 | 10:40 AM
  #21
Kerbmonster's Avatar
Default Magnum Overheating
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
<div class="FTQUOTE"><begin quote>Originally posted by: Shallow_Hal
how do i check that?</end quote></div>
The manual (Clymer) just says have the cap pessure tested it does not say how, I would bring the cap to a automotive rad shop and ask if they can do it.</end quote></div>
agree with that, and to bleed it, run the bike with the cap off and see if it bubbles all the air out of it and the coolant level goes down
Old Mar 26, 2009 | 02:30 PM
  #22
Shallow_Hal's Avatar
they will pressure check the radiator cap at o'reilys. what type of coolant do use for the magnum 425????
Old Mar 26, 2009 | 04:37 PM
  #23
regualar green stuff, with a 50/50 mix, u can buy it mixed or save money and mix it yourself
Old Mar 28, 2009 | 01:39 PM
  #24
i took apart the water pump. i think to do it correctly i should have removed the block from the frame??
the empellor looks fine, but there is play in it. not back and forth, but up and down. the shaft does look to secure. a lot of play in it. also, when i took the cover off, the nut for the empellor was already off and it is chewed up pretty bad.
i know i need a new nut, but should that play be in the shaft?? hopefully i have found my answer??
Old Jun 8, 2020 | 07:04 PM
  #25
Jess Trusty's Avatar
What did you figure out mine does the same thing
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
