ATP 500 HO front end camber
Old Mar 25, 2009 | 09:27 PM
MN04ATP's Avatar
Default ATP 500 HO front end camber
My '04 ATP 500 HO has quite a bit of negative camber. I didn't measured the camber yet (battery in my digital angle gauge is dead), but it's quite obvious.
Camber on on my '80 car is set to 1/4-1/2 degree for "advanced street", and 0 degrees is stock ("street"). I know about alignment settings for old Corvettes but don't know what's best for ATVs.
The vast majority of my ATVing is around our wooded lot with a modified plow on front and/or a trailer behind - not much recreational riding.
What is a good camber setting for my machine and typical use?
Are toe-in and castor adjustable too? If so, what numbers do you recommend?
Old Mar 25, 2009 | 09:51 PM
Doctorturbo's Avatar
GOT BOOST!
Are you sure camber is adjustable on your quad?
I have never seen adjustable castor or camber on a stock quad front end. Toe, sure, but not camber and castor.
Old Mar 26, 2009 | 08:32 AM
The toe adustment is the only adjustment I could find in the ATP manual. The back of the front tires should be 1/16-1/8" in further than the front of the front tires. If the camber is really bad you might try heavier duty springs in the front to take any sag out.
Old Mar 26, 2009 | 12:10 PM
MN04ATP's Avatar
I saw that toe-in is adjustable but I wasn't sure if there were shims for changing camber. I will probably switch to HD springs anyway because I have something attached to the front so often.
Thanks for the responses.
PS Moose, I agree on the way, the truth, and the life. [img]i/expressions/present.gif[/img] [img]i/expressions/sun.gif[/img]
Old Mar 26, 2009 | 12:34 PM
I'm not sure on what they have available for a heavier duty spring. You might try calling a dealership and see what they say. Amen on the PS.
Old Mar 26, 2009 | 10:13 PM
MN04ATP's Avatar
I just measured the camber: negative 4 degrees with the plow lifted, negative 1 degree without. That tells me the stock 64-113 lb. springs are shot. I just ordered a pair of heavy duty 80-145 lb. EPI springs for $88.50 including shipping.
I will post my questions about swapping springs once they arrive and post camber measurements with the new springs after that.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
metal249
Jul 28, 2015 09:35 AM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
