Sp500 Strut cartridge depth position question?
Old Apr 3, 2009 | 05:18 PM
jes Si's Avatar
Default Sp500 Strut cartridge depth position question?
Hi everyone,
Thanks for looking..Maybe one of you guys can please help a fellow rider.
03 Sportsman 500H.o ,bought it from a guy that had installed Ranger springs
on it. Needless to say, It rode like an old wagon stiff as a morning tee-pee pole.lol
So on my quest of returning it back to stock, I noticed the cartridges were jacked up &
out of place.
Got replacement strut cartridges and need to know how deep in the strut holder do I need
to mount these struts?
I have an after market service manual that just says to scribe a mark on the position of the old ones and transfer it to the knew ones.
But in my case that is not any help.
Does anyone know?
Old Apr 3, 2009 | 05:38 PM
upnort's Avatar
If you got stock they should be bottomed in the housing. Kinda sounds like I had done to my old machine. Had done the hocky puck lift and puy the cutout pieces in the bottom of the strut housing. But they were at the bottom origionaly.
Old Apr 3, 2009 | 06:28 PM
TLC's Avatar
TLC
Did the guy try to put on 05 or newer springs? In 04.5 Polaris made taller 8.2" struts/springs from 6.7"
Did the guy compress the taller new 8.2 springs on the shorter old 6.7 struts maybe?
Old Apr 3, 2009 | 08:09 PM
jes Si's Avatar
Thanks upnort. By the way what year was your sportsman?
According to the manual which cover 1996-2003 models states that placement of strut cartridge may vary.
TLC ,about the length of springs he had on, Yes he had them pretty compressed.
Without measuring them, they appear 3 inches taller than stock.
Old Apr 3, 2009 | 09:25 PM
upnort's Avatar
I had an 02 500 and an 03 700. Strut can be clamped up a bit I imagine but mine were bottomed out. The strut is to dampen the rebound of the springs and absorb bumps.
Old Apr 3, 2009 | 10:36 PM
jes Si's Avatar
yea I just wasn't sure on how the placement would affect the up or down travel of the strut rod in terms of bottom'n out ... I'll go with your advice tho.
Thanks for your help upnort.
Hey have any idea on how to remove a stuck roll pin from the axle yoke?
Old Apr 3, 2009 | 11:28 PM
TLC's Avatar
TLC
See for yourself. http://www.powersportsnetwork.com/en...e2=13488&go=Go
Old Apr 4, 2009 | 12:36 AM
jes Si's Avatar
that would explain things TLC.
I can not see what performance advantages the previous owner would get out
of doing such a thing. I mean it was so stiff that it felt It had no suspension at all, & I'm not exaggerating either.The rear has a 2" collar on the shocks which I am going to take off next. Just looking for a stock smooth ride & stock ground clearance of 11" is good enough for me. and is one of the reasons why I chose this atv not to mention the IDS.
Old Apr 4, 2009 | 11:16 AM
upnort's Avatar
The previous owner may have had bigger tires on it and tightened up the front end to keep it from rubbing when they hit bumps. That is why I did mine.
Old Apr 4, 2009 | 06:27 PM
jes Si's Avatar
Originally Posted by upnort
The previous owner may have had bigger tires on it and tightened up the front end to keep it from rubbing when they hit bumps. That is why I done mine.
Yes now that you mention it upnort ,he did mention he had bigger & more aggressive tires.
Kyle5050
Dec 13, 2019 04:25 AM
dwhipper61
Aug 27, 2015 11:01 AM
4464
Aug 21, 2015 01:46 AM
Polarisman1123
Aug 13, 2015 08:13 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
